MegaSquirt + Turbo + LSX.. Pro's or Con's?? Opinions..
Old 05-05-2008, 04:12 PM
1QuickT-A's Avatar
Default MegaSquirt + Turbo + LSX.. Pro's or Con's?? Opinions..
We want to put together a cheap Turbo setup using an extra motor that I have laying around here. I know "cheap" and turbo don't really go together, but I can't afford to do it like some of you guys have done SO give me your thoughts (and prayers.. lol) on this setup..
I thought about Megasquirt only because its kinda cheap, rather easy to use and it would be easier since this is NOT going into an Fbody car. I also know a guy that has a good bit of experience with it. How well would it work on a turbo/lsx setup is the question?? Would I be better off with just using the stock pcm and HP Tuners? BS3 or Fast is out of the question totally.. What would be needed to make the Megasquirt work??
IF and WHEN we do this I will probably use a Malibu or Regal body. The engine would be a 37X (.040 6.0L block) with copper gaskets and probably a cheap ported set of 6.0 heads. Plan to use a Victor Jr or GMPP intake with an elbow. We plan to use truck manifolds flipped and probably a T-76 or MAYBE an 88... I have no clue about injector size either?
Lets converse!
Old 05-05-2008, 04:43 PM
JoeyGC5's Avatar
Parish and the Omaha guys have been doing well with it for last couple of years.
Old 05-05-2008, 04:59 PM
1QuickT-A's Avatar
I totally forgot about Parish using Megasquirt.. Maybe he will chime in..
Old 05-05-2008, 05:13 PM
LSJM1's Avatar
Using a victor or gmpp intake with an elbo and all that is not cheap. Cheap is using the truck intake that is what I'm doing.I think I'm going to use stock pcm with a SD tune and run e-85 with 83lb injectors.
Old 05-05-2008, 10:17 PM
will62085's Avatar
megasquirt II all the way. I never had any issues with mine other than lack of experience. It has a pretty steep learning curve, but once figured out, i could not ask for more!
Old 05-05-2008, 11:14 PM
mightyquickz28's Avatar
Will62085, what did you use for a trigger? Did you go with the 36/1 wheel or adapt your intake to use a distributer or ???? I have a MegaSquirt II sitting right beside my laptop and I really would like to use it to fine tune my upcoming setup. Can you impart any wisdom on setting one up? I went to their website and tried reading the monstrous volumes of people putting MS on basically every internal combustion engine since the dawn of man. Not too much there for 'us' though. Sounds like you and a couple of others have figured it out.
Old 05-06-2008, 12:54 AM
valiant65's Avatar
Megasquirt is what I have on my mind too. I have understood that the problem with it, is triggering or controlling the stock coils.
http://www.msextra.com/ms2extra/MS2-Extra_LS1.htm
Old 05-06-2008, 08:27 AM
1QuickT-A's Avatar
How did Parish do it on that Ford Fairmont they put the Turbo 5.3L in??
Old 05-06-2008, 04:15 PM
will62085's Avatar
I use a 4x obdII crankshaft position sensor (96+LT1) to trigger mine. Im sure the crank or cam sensor on an LS1 can be made to trigger one as well?? I have not messed around with LS1's too much so im not very familiar with the sensors and such.
Old 05-06-2008, 10:23 PM
Will62085- Just went to your 'turbo buildup' page. Nice! Was that dyno graph with the Megasquirt in place? Pretty outstanding power at such low RPM. Do you still have your Megasquirt "STIM"?
Old 05-07-2008, 07:38 AM
1QuickT-A's Avatar
Some of the mustang boys are using Megasquirt with a MSD crank trigger setup and LSX Coil Packs.. But there is obviously a way to make the MegaSquirt work on a LS engine because parish already did it..
Old 05-07-2008, 07:55 AM
There's a guy/company that sells a modified stock PCM for the LT1 faithful that has Megasquirt II installed IN the PCM itself. No crank trigger is need. Just unplug the old PCM, install this guys and hook up your vacuum tube to the built in MS MAP sensor. He's obviously found a way to get a 'soft' signal from the Optispark. It's near plug and play but he really wants a pretty penny for the setup. I guess it's a question of paying it all up front or wasting a lot of time chasing down parts, asking questions, trying this and that till you ultimately achieve what this guy was able to do. I wish I could afford his setup but I just can't at this time. I'd love to know how he was able to do it. Maybe if about 6 of us went together and bought ONE of his boxes, then took it apart to see what the guy did, we could get an idea of what to do for our own setups.
Dreaming out loud,... hehehe.
Old 05-07-2008, 08:32 AM
Pathological Modifier
Ryan K's Avatar
I setup a friends car to run the megasquirt for fuel control and the factory PCM for all of the other engine functions (timing, IAC...). Its been working flawlessly for two or so years.
They definately have there advantages of the the stock computer for fueling.
Ryan K.
Old 05-07-2008, 08:51 AM
will62085's Avatar
Yes the megasquirt II was in place then. It was driving a 12v cylinder coil directly via the VB921 high current ignition driver circuit. needless to say, this was not enough. Just after hitting 14psi (about 4200rpm) the spark blew out. Plugs gapped at .030. The only way to get enough power to the coil was to increase the dwell time, which inevitably burnt up the vb921.
I've since hooked the vb921 output to an MSD box which charges the coil, not more load on the MS, and not more spark blow out! There is plenty of info on adding MSD to your spark controlled MS on msefi.com and megasquirt.info
Yes i still have my STIM board, i've built two more MS's for friends cars and i used the stim on each. It is definitely a good buy
Old 05-07-2008, 11:05 AM
Zombie's Avatar
I'm running an MSII but i'm only using it for fuel at the moment because I want to retain the factory ECU's excellent knock detection ability until I see more progress on the MSII knock detection.
The MSII will drive the LS1 coils in a wasted spark setup without any trickery. There is info out there on how to set it up.
Old 07-01-2008, 01:18 PM
bigturboz28's Avatar
Default Ms-i
Currently using MSI with no issues, with the new firmware (y) you can use the stock LS1 cam and crank sensors to control the coils directly in wasted spark mode. Do a search for "mobythevan". Megasquirt is very reliable and easy to use, and you can't beat the price!
Old 07-01-2008, 02:04 PM
markp03's Avatar
my buddy runs it with his ls1 with a whipple superchager and nitrous which is running on e85. no issues works great and he loves how when he is driving to the track he can pull fuel while crusing and get 35+ miles to the gallon on e85.
Old 07-01-2008, 05:13 PM
night ryder's Avatar
im going to be running the MSI and lsx msd box. i have run the msI on a few cars, and have nothing but good things to say about them
Old 07-01-2008, 05:25 PM
Got any pictures of the trigger for the MS? Are you using the 36/1 wheel?
Old 07-08-2008, 04:51 PM
mobythevan's Avatar
The only problem I am having is controlling 150 pound injectors with the low resolution of MSI. My idle surges like a monster truck, but otherwise runs awesome.
Quick Reply: MegaSquirt + Turbo + LSX.. Pro's or Con's?? Opinions..
