need alkycontrol help
Old 05-18-2008, 03:01 PM
Blown Ta's Avatar
Default need alkycontrol help
noticed my alky control kit was not coming on at the track yesterday. i hit the test button on the controller, and it works, but its not coming on by its self. any idea what it could be???
Old 05-18-2008, 05:14 PM
BoostnTBSS's Avatar
What map sensor are you running? check the baseline settings?
Old 05-18-2008, 08:02 PM
FastBlackTA's Avatar
As noted above, check the baseline settings and check your vacuum lines to the map sensor so make sure they are OK.
In addition, if the **** is not set to a level equal to or over 4 it will be "lazy" and it might take a while for the green light to turn on. If your tuner tuned the system with the **** on a lower setting, don't sweat it.
Old 05-18-2008, 08:15 PM
Blown Ta's Avatar
it has a 2 bar map sensor, the it was tunned with the **** all the way clockwise. not sure where the 2 settings on the controller are supposed to be set at. also i have the older kit, it only has the red led.
Old 05-18-2008, 08:36 PM
Jake@EPP's Avatar
You might consider giving Julio a ring, hes a great guy to talk with and is sharp when answering anything and everything on his setup.
Try running a volt meter on the map output wire (usualy green), it should be somewhere around 2.5v with key on engine off.
Old 05-19-2008, 04:28 PM
Blown Ta's Avatar
called julio today, got it fixed, the turn on **** on the controller was set too high., Jake@EPP you are right he is a nice guy, and helped me fix it in 5 min.
Quick Reply: need alkycontrol help
