blower tuning
Old 05-31-2008, 08:02 PM
stingr's Avatar
LS1Tech 10 Year
Default blower tuning
Can a diablo predtor tuner be used to tune for 6.5psi boost? Or do I need to send it in to have a program loaded on to it? or can I even use it to tune for boost?
Old 05-31-2008, 08:17 PM
kwiksilverz28's Avatar
You need to get someone to tune it on a dyno. Having a so so tune under boost is an invitation to break stuff....
Old 06-01-2008, 06:20 AM
EPP
EPP's Avatar
No it can't. You need to be able to richen up the fuel mixture to 11.5/1 at wide open throttle above 5000 rpm and you need to be able to pull timing out to approx 18 degrees in the upper rpm range. Bob
