What fuel setup for MPT-70 kit?
Im just about ready to start purchasing my fuel setup for my build. The basic specs on the build:
DIY turbo kit with MPT-70
TH350/9"
Full weight SS
Meth inj will be added later when its time to up the boost
Ive decided that 60# injectors should be sufficient. Ive been leaning towards the racetronix fuel pump setup. What kind of power will that support? Will I need to upgrade the fuel lines? I know Ill need aftermarket fuel rails. I dont really have a dead set "power" goal, but should be hovering around 6xxrwhp give or take (keep in mind the stalled TH350 and a 9").
So what do you guys recommend as far as pump setups, fuel lines and the such for my application?
TH350/9"
Full weight SS
1 Post
TH350/9"
Full weight SS
TH350/9"
Full weight SS
As for me.....just sold my turbo, so I now have the most overbuilt H/C car in the planet concerning fuel/tuning/rear-end, etc
Stock cube engine? For 600WHP and below 60's should be fine for injectors. Aftermarket rails too. I'd recommend dual Walboro's to leave room to grow. I personally run a Racetronix 255 w/ hotwire kit, but I also have a return fuel system. I'd start w/ the dual walboros, rails, 60's and a pressue gauge and see how that runs. Making a return or boost referenced system isn't hard....but it'll cost $800 or so and no sense spending the coin if you don't need to. Just my $0.02
