4.00 bore x 4.00 stroke.....good for FI
If I'm correct you can just hone the LSX iron block and you would have a 4.00bore, then just use a 4.00 stroke and I'd have a 402ci. RIGHT?????
That with a single turbo, FI-98X will be the turbo. OFI kit.
402ci + FI-98X + 6 bolt heads (probably ETP) + sheet metal intake
Main question: Is that the best bore/stroke combo?
full time race gas
weekend car only
street car/show car
full time race gas
weekend car only
street car/show car
And before you ask, heck YES, 1,700 RWHP would be plenty. My goal is 1,500RWHP using an FI-98X on a ?????? cubic inch motor.
I guess the question is: the chart with the FI-98X says its good to 1,975 hp. How does one build a motor to max out the potential of a turbo..or get damn close to it?
You have to match the compressor map and turbine map to an engine. Alot of even the professional racers don't do this and end up with backpressure problems or hot outlet temps. I can plot it all out for you if you need it.
If you could plot it out I'd appreciate it, I'd like to see it. Then I could consult with my builder.
Thanks.
Ok....doing the #'s, you need ~161 lbs/min, PR 2.84 would be needed on a 402 revving to 7K rpms. This means you need a turbine flow of about ~75lbs/min. The FI98-X would be in the 70% eff range...which is good. Turbine side would need the larger A/R to reach turbine flow.
Nate
7 Second Club
Keith,
I think we can. Looking at the data no the run and from what a couple in "the know" have said we have an easy 500rwhp on the table.
Drturbo,
We've been a 1.301 60' on the small tires. On the big tires we've inched the 60' down .03 each pass by adding alittle to the 2 step RPM. Each time we add it picks up .03 EXACTLY to the number.
Drturbo,
