looking to procharge the 408
Old 08-12-2008, 08:49 AM
89Formulaws6's Avatar
Default looking to procharge the 408
over the winter im possibly thinking of procharging my 408 when i get my cnc l92 heads and if that aftermarket intake comes out
first off ill say this ive never delt with a supercharger before only a turbo
i have a forged bottom end. and im looking to go e85 with this
question is which procharger would be best for a 408 i know some people say theres a quiet version and a loud version as well
fuel? injectors are obvious but as for fuel pump willl i need 2 or what? i currently have a walbro 255 anything else i'd need for fuel
should i get head studs? are stock headgaskets a no go?
i currently dont have main studs just gm bolts should i upgrade to studs too on the mains?
anything else i should be concerned about
intercooler and pipeing ill fab up which wont be a prob aswell as a bov
im really not sure what kinda boost/power it could hold but i figured 6-700whp is possible isnt it?
Old 08-12-2008, 09:15 AM
jmdgto's Avatar
see bob at epp. he is a sponser on this site he has a complete procharger kit for your car. you will need to upgrade your fuel system. add another 255 fuel pump. http://www.exoticperformanceplus.com....html?item=798
Old 08-12-2008, 09:42 AM
98transguy's Avatar
i would say a minimum of an f1a thats what Bob runs on his personal car which is a 402 and performs very well.I would upgrade to head studs.Bobs car runs about 18# of boost and somewhere north of 800rwhp.Dont hesitate to give him a call and he can discuss other items u might need and he also has the best price around on prochargers.
Old 08-12-2008, 10:07 AM
EPP
EPP's Avatar
Thanks guys! Here is the build on my '99 that has a 408 with an ATI ProCharger F-1A.
http://www.exoticperformanceplus.com...Car.php?car=12 Bob
Old 08-12-2008, 05:15 PM
thanks for the thread bob
few questions why do the split the charge pipe on the outlet of the procharger? also do they have a setup that mounts in the location of the ac compressor by chance?
money is going to be a factor so thats why i wanted to see what its gonna take now so i dont rush into anything
thanks a ton!
Old 08-12-2008, 08:13 PM
EPP
EPP's Avatar
thanks a ton!
With the ProCharger twin intercooler system the charge pipe gets split up.
With our front mount intercooler option there is no split.
Here is our complete kit.
ProCharger only has one location for the blower on the f body.
You could possibly use the ProCharger GTO bracket to move the blower over to the driver side top of the engine, or use the ProCharger C5 bracket to locate the blower on the passenger top side. More than likely you would end up with additional cost in trying to make something like this work on an 98-up f body. Bob
Old 08-12-2008, 09:01 PM
what i was asking was why do they split the charge pipe and go into 2 intercoolers wouldnt there be more of a pressure drop when it reached the t/b?
like whats the benifite? maybe cool iat's?
Old 08-12-2008, 11:46 PM
macleod's Avatar
The twin coolers are what come with teh kit but to run more boost teh FMIC is a must.
Old 08-13-2008, 05:25 AM
EPP
EPP's Avatar
The twin intercoolers was ProChargers method of intercooling the LT1 and LS1 f body's. The air is channeled up into the intercoolers the same way it enters the radiator. Since there was not enough room for a large intercooler under the car, they split it into two smaller intercoolers. This method works quite well until you get into the higher boosted applications that are 14 psi and above. Bob
Old 08-14-2008, 06:18 PM
BLOWNBLUEZ06's Avatar
Put one of the F1's on that bad boy! You won't regret it!! EPP will make it fly!
Old 08-15-2008, 05:32 AM
EPP
EPP's Avatar
Thumbs up
Yes indeed! Bob
Old 08-15-2008, 04:56 PM
blownblue what exhuast do you have?
bob if all goes well with my position i should have enough to get a procharger setp and some better heads this winter so ill keep you in mind
thanks
Old 08-17-2008, 08:10 AM
EPP
EPP's Avatar
Thumbs up
thanks
Sounds good, thanks! Bob
Old 08-17-2008, 06:15 PM
Jimmy P's Avatar
Since its a 408 I would go with a F1A or bigger. My D1SC ran out of steam at the high rpms on my 402.
Quick Reply: looking to procharge the 408
