STS meth question
STS meth question
After installing the boost controller/meth injection system I have a problem. The "Activity" light flashes when the switch is in the "On" position at idle and flashes faster as the engine is revved. What did I do wrong?
Sounds like the meth is spraying at idle ... pull the intake pipe where you mounted the nozzle and check to see if it's spraying. I think the pressure switch has terminals for 'normally open' and 'normally closed', so if you hooked it up 'normally closed', it'd spray the meth at idle, and stop spraying at 4psi instead of the reversed.
