blown 355?
blown 355?
looking at possibly buying a trans am with the following motor:
350 bored to 355
Vortech V-2
Vortech FMU
Vortech T-Rex in line fuel pump
TPIS Airfoil
CC306 cam
Crane 1.6 roller rockers
Crane Hydraulic Lifters
Crane Valve Springs
AFR street 180heads
9.5:1 Compression
Fireball HI-6R ignition
stock coil and optispark
AC Delco R44LTS6 spark plugs
AC Delco plug wires
Hooker Super Comp Long Tubes (1.75" primaries, 3" exhaust)
Flowmaster 3" catback system with a catalytic converter
My question is, this is a stock rebuilt bottom end. How much bost should i run, and what kind of power should i expect with a good tune? Also what injectors would you guys reccomend? Might also swap in a better blower cam. Thanks guys
350 bored to 355
Vortech V-2
Vortech FMU
TPIS Airfoil
CC306 cam
Crane Valve Springs
AFR street 180heads
9.5:1 Compression
AC Delco plug wires
Which V-2 is it? It should say 'S' or 'T' after the V-2. If it says nothing it will be the S.
I agree you should be in the 460-500rwhp range with 8#, depending on the tune.
Jim
Jim
