Turbo 94Z
Turbo 94Z
I have a 94Z that has a small cam...LT's and a few other things....I want to put a single turbo on it....How would I go about doing that....should I buy one of those make it yourself Header kits from summit and fab my own Turbo Header? or does somebody sell one of these...Mind you this is a budget minded build for experimental purposes...I have a garret Turbo that I will be using for now just to get things going Would I need to drill and tap the Oil pan for the oil lines or is there a reloction kit for the oil filter that I can put a couple of fittings into for this...I am turbo stupid but I really want to make this happen....It will be my DD eventually and i want to be able to drive this thing anywhere but at the same time if a vette pulls up next to my Crappy ole LT1 I want to be able to play....So any ideas or if somebody has already taken this challenge and was succesful pictures would be great....
Thanks in advance,
Jason
Thanks in advance,
Jason
Talk to jose@forcedinductions.com,i think he has a set of prototype,like the first Pro turbo headers ever done for an lt-1,I bet he would let go cheap,he said he was cleaning shop,then you just have to fab the easy stuff,cause the headers are what suck to make.
I have a manifold Kit for sale. Some of the welds are big and not so pretty. Here are the specs.
https://ls1tech.com/forums/showthrea...732&highlight=
