turbo size?
turbo size?
Do not have the time this complete site, i was wondering what size turbo for 400cu.in. lsx lt will be a single turbo only. Truck manifolds 6 bolt heads. If more info is needed ask me. Are people running 100mm+ turbo's? What ar's are poeple running? thanks for any help JC
If you are going to run a carb check out carb solutions unlimited, they have the best carbs for blow through.
If you want to run 8's you will need a big turbo but a 100+mm is NOT needed. I would run an EZ-94X Dual Ball Bearing Billet turbo from forced inductions. Its not cheap but Its the best of the best and can make 1700+hp. Call Forced Inductions, they can help you pick exactly what you need.
