My build (truck/C6 manifold setup)
#241
Thanks, I havent made another line yet but it is on my to do list. Right now I'm battling my injectors (57# LOW impedance). They refuse to idle stoich so I ordered an adjustable boost referenced FPR and plan on installing it and running a return line this coming friday. Once I get that issue fixed & retune the car, then I can start on the AC.
#244
No I'm gonna turn the pressure down to 44 psi, I have the IPW turned all the way down and it still idles a little rich. If I could have gotten it to idle stoich with my low impwdance injectors I would have held off on the return style fuel system a little longer. I'm leaving the evap line in place and running a -8 return line, later on I'll step up to a bigger feed line also.
#253
Well had a little problem with the car not wanting to isdle stoich so I had to convert to a return style system with a boost referenced FPR so I could lower the fuel pressure. I plan on going to the track this saturday. I also had the blow off valve on wrong so I was loosing a lot of boost by it bleeding off to atmosphere.
Here are some pice to the fuel rails & regulator.
Thanks
4" Dynomax Ultraflow race. I hate how it sounds dumping right under my seat, I plan on running 4" all the way back and maybe even welding in another ultraflow further down when I have the time and money.
Thanks
#258
I used a flange off a 95 toyota avalon catalytic converter. It uses a flat washer style gasket but the receiving groove in the C6 manfold is so deep I had to use 2 of the gaskets to get it to seal up good.
Yeah, the rails are Speed inc high flow rails. Let me know what line adapters or fittings you want to know about and I'll get you the pn's.
