? blown head gasket
? blown head gasket
I'm having some white smoke coming from my engine and from exhaust, I thought it might have been a blown head gasket but when I drained the oil it looked clean, when I pulled the intake off there was alot of oil build up in the exhast chambers of the heads, could this be a bad valveseat or seal? also has anybody done a rebuild on a vortec sq9 supercharger? this may be the source of an oil leak I was having, there was alot of oil in the impellar side of the supercharger through the mass air and into the aftercooler. I thought this was the cause of the white smoke but I put the car back to stock and it continued to smoke. any ideas????
How does the engine run ?
If oil's everywhere, its probably stinking blue smoke ( as opposed to odourless or antifreeze smelling white ) and melted pistons.
The enging was misfiring and there seemed to be a rich smell to the smoke, also when I pull the heads will I also be able to see if there is any damage to the pistons or rings?
