procharger p1sc oil help
Old 09-29-2008, 10:05 AM
chiln1208's Avatar
Default procharger p1sc oil help
Just to start, I'm pretty new to the whole FI thing and I'm not very mechanically inclined so with that out of the way I'm getting an p1sc put into my firebird and I'm wondering about changing the prochargers oil. I'm probably going to have the shop that is doing the install change the oil for me but I was wondering in case I wanted to give it a try, how hard is it to do on your own. I got a used kit so no manuals or anything so any advise would be greatly appreciated. Also I'm hearing change the oil every 6000 miles but I don't drive the car very much so I'm thinking it would take me 3 years to put on that many miles. Is there any time limit to be changing the oil?
Old 09-29-2008, 01:08 PM
Customizing Director
MadIceV8's Avatar
Not sure about the time limit on the oil at all. Changing the oil isn't to hard, just sometimes a little hard to get to. There is a drain plug at the bottom. And then a fill on the top with a dipstick attached (flat head type bolt).
Old 09-29-2008, 06:20 PM
EPP
EPP's Avatar
Here is the manual in a pdf form. http://www.exoticperformanceplus.com...html?item=1043 Bob
Old 09-29-2008, 06:39 PM
forcd ind's Avatar
when you get it back, i would advise pulling the dipstick, ck the oil level so you know where the fill mark is, and ck it from time to time
Old 09-30-2008, 12:45 PM
chiln1208's Avatar
Thanks for the responses everyone. So does anyone have an opinion on the life of the oil in terms of time instead of miles.
Old 09-30-2008, 04:37 PM
9t8z28's Avatar
I change mine when I do the engine oil which is 2K miles.
Quick Reply: procharger p1sc oil help
