Will this support 1000rwhp
I bought this setup from a guy on ls1gto.com and am wondering if it will support 1000rwhp and if I will need to get different injectors.
Here is what he had in the kit, I should be getting it from UPS in a day or two. Magnafuel Pro525 pump #4302, aeromotive inline filter, aeromotive regulator, rails, fuel pressure gage, y-block, -10 an lines
On my current setup I was running 60lb injectors, KB Bap, 255 Walbro pump, Fast Fuel rails, Meth Injection (was at 678rwhp)
I will now be putting in the forged 408 and pushing about 19psi and should be around the 1000rwhp mark and want to make sure I have the components to hit it. I dont want to run into surprises once everything is installed. It is better for me to buy additional parts now and only have to install once Here are some pics from that thread.
http://www.ls1gto.com/forums/showthread.php?t=277045
That pump will not make it to 1000rwhp good to about 800 on boost...the Meth will help some but really should have a bigger pump to be safe. Also yes you will need larger injectors and a driver box.
Nate
Nate
