Fuel Pressure Problems
Old 12-25-2008, 02:17 PM
MTBSully's Avatar
Default Fuel Pressure Problems
Just installed my holley fuel pressure regulator on my LT1 a few weeks ago. Also, yesterday i wanted to test my new fuel pressure tester. Hooked it up to the schrader valve, primed the pump, and:
Needle went to about 20psi, then dropped back to zero as soon as the pump shut off. Same result after two more primes.
Once i got the car running, i have about 23psi.
Supposidly, fuel pump is new walbro 255. Im thinking fuel filter (which im going to do anyways). Could it be the regulator? Its brand new.
Old 12-26-2008, 11:49 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
It isn't the filter
You have to adjust the regulator after you install it.
Start the car & adjust pressure up to 45#, then reconnect the vacuum line.
It may still bleed off after you you shut the car off.
