losing fuel pressure?????
i have a 1998 ss camaro and i keep losing fuel pressure when there is a load on the car. when i try to do a pull the pressure drop to 38lbs. i have already replaced the fuel pump, regulator, and filter. still no chang. car has been modded with full ls6 short block with ls6 heads, ms3 cam/valvetrain, bbk intake. estimated 440rwhp. any help will be apprciated
well if you have fuel system in your car ,, check the the Hoses ,, if they are big ,, for sure u will lose pressure
check the hoses ,, are they 4 an or 6 an or 8 an
i got a theory i use it myself ,,, if i use Welbro 255 inside the TANK ,,, + Bosch 430
with 8 AN Hose from the Bosch to the Fuel rail ,, i will lose pressure ,,, so i will use 2 Bosch
so check your hoses they might be to big ,,, i tried my Theory here in my country ,, and i guess i am right about it ,,,
hope that info will help u
the car is fixed. pulled the pump back out and the line was pinche where the spring is on the unit. put a new hose in and holds great. thanks for all the help guys
