keep blowing fuel pump fuse
Old 03-01-2009, 12:59 PM
BBldr18's Avatar
Default keep blowing fuel pump fuse
Aeromotive fuel kit installed n an LS1 keeps blowing fuses. Any ideas on what could cause this? Would it b the relay? Pretty sure the pump is still good and all...when I put a new fuse n 2day I heard the relay pop on for a second and then turned off and blew the fuse. Thanks 4 the help!
Old 03-01-2009, 04:42 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Are you running it with the stock wiring or a separate power source? The stock wiring is not capable of handling this much current.
Old 03-01-2009, 08:09 PM
BBldr18's Avatar
no its a separate source
Quick Reply: keep blowing fuel pump fuse
