Will it take it (walbro 255 fuel pump)
I just had a 403 stroker (ls2) installed in my 2002 camaro with new 42lb injectors (green tip) and a 255 walbro fuel pump. Im going to spray around 150-200 shot of nitrous. Im expecting around 475 rwhp N/A and around 625-675 rwhp with nitrous. So do you think the walbro will hold that amount of fuel pressure or volume(or horsepower)?
LS1TECH Sponsor
You are on or slightly past the edge of what a single pump should support.
Also you may have a sharp pressure drop when you hit the nitrous due to the stock fuel line/regulator arrangement.
Feel free to give me a call to discuss some options for your setup.
I have dual pump kits as well as complete fuel systems that will easily support your power goals.
