LT1 383 what size injectors?
Old 03-07-2009, 03:26 PM
dave97transam's Avatar
Default LT1 383 what size injectors?
I have a 97 TA LT1 that I am building to a 383. The machine shop is porting the heads and matching a cam to the head flow. Pace setter LT's, LTCC ign with LS2 coils plenty of spark.Ihave read sooo many dif setups for injector sizes I have no idea what to buy. I an guessing 36 to 42Lb any suggestions would be welcome.
Thanks Dave
Old 03-07-2009, 03:41 PM
FICINJECTORS's Avatar
Thanks Dave
the right size injector is based on HP. We sell a ton of #36 @ 3 bar (43.5) for your application.
Rich
Old 03-07-2009, 04:02 PM
Rich
Which injector p.n. do you recommend from your site? Do I understand this correctly a #36 inj is putting out #43.5 on my car? Will I need to change from stock fuel pump?
Dave
Old 03-07-2009, 04:56 PM
Dave
Your car should be at 3 bar (43.5) fuel pressure not 58 like the ls1's.
stock pump will be fine for 36's
pm sent
Rich
Old 03-07-2009, 05:04 PM
PM received
Dave
Quick Reply: LT1 383 what size injectors?
