Factory PCM & 16 injectors?
I would guess that it would be too much current and probably overload or damage the ecu. Similar to puttind in a set of low Z injectors. Im just speculating. Im sure there is an injector big enough for what you need, as you could see 1500-1800 hp with just 8 injectors. I believe the Megasquirt will run 16 injectors.
