racetronix fuel pump harness install
Ok, so tonight I finished up installing my racetronix fuel pump. Now tomorrow I am running the harness for it up to the alternator. My question is how did you guys run the harness and where did you mount the items like the relay and the fuse and all that. Did you mount any of it inside the car and have the wires come through your trap door above the tank or do you run the wires completely on the outside of the car and have the wires come up around the tank somewhere? There are no real directions with the harness so just curious what you all did. Thanks
The easiest thing to do is follow the brake/gas lines on the driver side of the car.
I mounted the relay/ground on the brake bracket thing right by all the electrical connections panel.
