Lucas 42.5# injector values
Old 03-15-2009, 03:13 PM
98Camarod's Avatar
Default Lucas 42.5# injector values
Does anyone have the correct values for the offset, short pulse adder, min injector pulse, and default injector pulse value for 58 psi? I got these from speed inc a while ago, and now I'm tuning for my forced induction setup and have a boost referenced regulator. I have the correct IFR values (value, since I have the adjustable boost referenced regulator), so I just have to get the other values.
Old 03-15-2009, 10:16 PM
405HP_Z06's Avatar
Here you go.
Old 03-16-2009, 02:56 PM
98Camarod's Avatar
Thanks! Do you have the values for the short pulse adders by any change? Do you know what fuel pressure that was calculated as?
Old 03-16-2009, 04:30 PM
405HP_Z06's Avatar
Leave the short pulse adder stock. 4 bar fuel pressure
Old 03-16-2009, 06:59 PM
98Camarod's Avatar
I guess that the IFR was figured on 42# vice 42.5#
Thanks again Aaron! Another big help for me. I'll try this out this weekend.
Old 03-16-2009, 08:51 PM
405HP_Z06's Avatar
Let us know how it works out.
Old 10-03-2009, 10:09 AM
NassyVette's Avatar
I thought I would attach the individual table files as they failed to load for me in the format posted above. (into HP tuners that is)
Also, I don't know how those offset table figures were calculated, but they did the trick. Before I entered the attached data into the injector tables my car was backfiring horribly under acceleration. Thanks to whoever figured it out
File Type: txt
Lucas_42lb_default_PW.txt (242 Bytes, 124 views)
File Type: txt
Lucas_42lb_IFR_Table.txt (225 Bytes, 128 views)
File Type: txt
Lucas_42lb_min_PW.txt (242 Bytes, 120 views)
File Type: txt
Quick Reply: Lucas 42.5# injector values
