Are my injectors going static?
They're stock 2002 injectors in a mild camaro.
I'm reading 61 PSI consistant thoughout the rpm range and seeing an average high of 86% duty cycle.
I've read that if you run over 80% then bigger then injectors are recommended, is this true?
