96lbs. or 120 lbs.?
Old 04-04-2009, 08:23 AM
1fast bird's Avatar
Default 96lbs. or 120 lbs.?
I am gonna be running twin 76mm turbos on my 402, and am looking for 1000 rwhp. I already have brand new 96lbs. injectors, but the twin kit is coming with 120 lbs. injectors. Is there any reason I shouldn't use the 120's or will the 96's be easier to tune. Not a huge dilemma, but will be when it comes time to tune.
Old 04-05-2009, 12:30 AM
6 Second Club Moderator
LASTLS1's Avatar
Run the 120's.
Old 04-05-2009, 12:36 AM
myfast70's Avatar
If you're interested in selling the 120lb set, let me know as I would be very interested in them. I need a set for my twin project too. Thanks!!
Old 04-05-2009, 11:49 AM
1fast bird's Avatar
I guess my question is, are the 120's as easy to tune as the 96's? Or is all the low impedence injectors the same as far as tuning goes?
Old 04-05-2009, 02:59 PM
myfast70's Avatar
They can be a bit tougher depending on your setup. The bigger the injector the harder it is to get the driveabliity perfect.
BTW, what pump are you running?
Old 04-05-2009, 06:02 PM
1fast bird's Avatar
A magnafuel 4303 external pump
