36lb bosch fuel injector problems
I just dialed in my car using the oem injectors. I tuned the car in OLSD and had all of my afr % errors fairly close. Idle was good too. Now I swapped a set of Yellow Bosch 36lb injectors in from fuelinjectorconnection and scaled my IFR table for 36lb @ 58psi. Now I am idling around 17-18 AFR and cruising is around 16-18 afr. WOT is also off about .6-.7 leaner than it should be. Does anyone know how to adjust the offset tables to get the right values in? I really need some help as I was told these are a direct drop in with only a IFR scaling. Thanks
