I need help guys...
I need help guys...
Alright here's what I've got...
98 Z28 M6
Patriot Stg 2 Ls6 heads - 220/230 .585/.585 112lsa
Pacesetters-ORY-Straight pipes to SLP dual tips
PB 25% UD pulley
LS6 intake-PPTB/bo white style-42lb. injectors
MSD wires, TR55 plugs
It will be a SD tune.
Here's my delema. I know I will need a fuel pump upgrade. I don't need the top of the line, just something to get me by on this setup. Also something relativly easy to install to help with time. Seeing how I will be doing an install on some of these parts and the tune by next weekend. Any ideas, or if you have what I need let me know!
98 Z28 M6
PB 25% UD pulley
I think the walbro or the racetronix is more than enough for what you have. Not that hard to install, there is a couple of great stickies on it. I did mine in about 3 hours , did not pull the tank, moved the carpet and cut an access hole but however you would want to do it.
