what to upgrade?
what to upgrade?
right now im coming up on the limit of my fuel system...
currently ive got an s10 flex fuel pump with a kenne bell boost a pump, -6 an feed and return lines with the stock truck fuel rails and regulator w/ 60lb injectors
im currently @ 600 hp and tq and theres some left but ill be adding more boost which will prob add over 100hp and I doubt it will handle it...
will the stock truck rails and regulator handle that much power, how about the -6 lines?
im pretty sure the pump will be past its limit so which pump would you recommend? (id prefer an external one if poss)
thanks, Gary
thanks, Gary
