03 Cobra injectors, what do I need to do?
I've searched around but cant seem to find any good threads about this. I bought a set of 03 Cobra injectors for dirt cheap and have the adapter harnesses to go with them. What else do I need to do to make these fit properly in stock fuel rails with a FAST 92 intake?
Agree, you should give Fuel Injector Connection a call. They can modify your injectors for the correct spray pattern. Stock these injectors are designed for dual valve heads and have a wide 'V' shaped spray pattern that isn't good for a single valve engine. The fuel will spray towards the port walls instead of on the back of the valve.
I had them, got rid of them. Like 405hp said, call Jon at FIC.com and get the right ones.
I had to take my intake off to look at a knock sensor and the forward and rearward port walls were spotless from
fuel washing the walls. They are supposed to shoot at the back of the intake valve.
