Fuel pumps in series help
Old 05-30-2009, 04:22 PM
ryanvv355's Avatar
Default Fuel pumps in series help
I have a Spectre EFI tank in my car with a Delco EP381 in tank pump which is supposed to be a 50-55gph pump at 58psi. I picked up an Aeromotive 450 lbs/hr pump which I plan to put inline just outside of the tank. Any opinions on this?
With the EP381 in the car I drop fuel pressure at about 70% TPS with the magnacharger only blowing 5psi. I want to blow 10lbs on E-85 here soon so I need a solution to the problem as well as greatly increasing my fuel delivery.
Old 06-04-2009, 06:50 PM
swv
swv's Avatar
Any luck with that setup. I been searching for info on that setup to. ANYBODY????
Old 06-08-2009, 10:53 AM
Nasty N8's Avatar
You are never going to pull more fuel through an internal pump. It can be a patch to help keep the pressure up but you will never add volume. If your pump is running out at 70% you need alot more volume. You need a bigger internal (or 2) or one large external sump fed.
Nate
