dual pump setup question
i plan on running dual 255's in the tank with stock lines and stock rails, aeromotive boost referenced fpr for an lt1, and 79# injectors. i hear alot of people having fuel pressure problems with both pumps running at all times, my question is how exactly would i set it up for the second pump to either be boost activated or a pressure switch ?
You need to run a separate relay and wiring for both pumps. We offer a complete installed Dual pump kit with full factory style wireharness. comes with a Hobbs switch for the second pump activation. Give me a call I will help you out.
Nate
Nate
