DIY Dual Pump question
I already have the bucket modded and going to grab a fitting to join the 2 together. + have wiring for them.
Would be ok to run Both pumps all the time with a regulator on the return? It's currently set @ 58 and will recheck it after the 2 pump install.
Currently I'm using a Magnafuel 4302 pump and sometimes it seems like it vapor locks when the car sits for a few, so going to stuff the pump back in the tank. The magnafuel pump is suppose to support 1000hp so it really moves the fuel.
What does everyone do with the little small hole in the top of the pump by the wiring connector? Where that small plastic line is suppose to connect? Plug it off ?
