Are these the same injectors?
Recently I ordered 8 used injectors (6 from one person, 2 from another) and they were all supposed to be 3800SC Series injectors - which I heard flow around 33.5lbs on LT1 Fuel Pressure.
The problem is, although the injectors look identical, they have different numbers on them. The first set has the following numbers:
24507495 and 0280155811
The other set:
24508208 and 0280155811
The second number on them does match, but does that make them the same injector?
The other set:
