Fuel Rails
Fuel Rails
i just want to know if there is any advantage of swapping from stock fuel rails. I expect to make about 520RWHP NA plus a 200-250 shot from time to time.
42lb injectors Ill upgrade the fuel pump once I do a little more research and see how high the duty posts when the install is complete.
Thanks in advance.
Thanks in advance.
42lb injectors will be close over 80% duty cycle at 520rwhp i would say to go with a set of 60lb. One walbro 340 maxed out at 550RWHP with my boosted motor so you might get 600RWHP NA. I Just pulled my 60lbs out. But with a 340 and 60lbs i could only put down 600RWHP With a bigger fuel pump i could have gotten more out of them
What kind of shot are you planning to run ?
LS1TECH Sponsor
The aftermarket rails will allow you to easily plumb a regulator & return line.
You will need this equipment if you plan to run a 200-250 shot. You factory system is not up to this power level.
I have pumps, rails & complete fuel systems in stock for your application.
Feel free to call me for more info. I can be reached at 724-322-8505 from 9:00am-11:00pm eastern time, including weekends.
