A fuel cell worth seeing!!!!!
This cell has to be one of the trickest parts i've seen/had in a long time. I was looking for a cell for my 56' bel-air and came across this Aeromotive unit. You can get it with either a A1000 or Eliminator pump installed with pre-filter. Will be putting into the car this week. Here are quick pictures to hold you over.
Aeromotive 18660 15 Gal Aluminum Fuel Cell w/ A1000 Fuel Pump Inside
[ click for larger image ]
Item #: A2718660
Our Price: $789.99
Quantity:
Description
Speed Unlimited carries the full line of Aeromotive components. We are an Authorized Aeromotive Warehouse Distributor.
Aeromotive #18660 Fuel Cell, w/ Built-in A1000 Fuel Pump, Aluminum, Natural, 15 Gallons, 0-90 Ohm Sender, Each.
A27-18660
Finally a complete, "in-tank" fuel system that is truly universal.
The Aeromotive A1000 Stealth Fuel Cell is an all aluminum fuel cell with an Aeromotive A1000 Fuel Pump and Filter, built right into the cell itself. Just like any fuel cell, these can be mounted any where, in any car. Simply strap the fuel cell in, hook up your fuel line to the pump outlet and your two wires and you're done. No more searching for a place to mount your fuel pump and pre-pump filter.
The Aeromotive A1000 Stealth Fuel Cell gives you an advantage over any traditional fuel system setup. Through an innovative baffling system inside the cell, the fuel pump inlet always has a constant column of fuel. In addition, the baffling keeps fuel at that same point even during extreme driving conditions, making it perfect off-road vehicles, drag racing, even autocross and drifting. This feature alone ensures the longevity and driveability of your fuel pump. Plus, the pump is inside the cell, so noise is drastically reduced and the fuel pump runs cooler longer.
The A1000 Fuel Cell is designed to be ideal for both EFI and Carbureted applications for street driving or racing, even if its forced air induction or naturally aspirated.
The proper regulator is required depending on your application.
For Carbureted applications, use Regulator, P/N 13204
For EFI applications, use Regulator, P/N 13101 or P/N 13109
Features:
All Aluminum Construction
15 Gallon Capacity
20" wide x 18" long x 10" tall
Tig Welded Natural Finish
Flush Mount Lid Assembly
(2) AN-08 Rollover-Proof Vents
Universal 0-90 Ohm Fuel Level Sending Unit
AN-08 Return fitting for bypass line from regulator
Built-in 100-micron Stainless Steel Pre-Filter
Aeromotive A1000 Fuel Pump with capability to support:
Fuel Injected Engines:
up to 1300 HP - naturally aspirated
up to 1000 HP - forced air induction
Carbureted Engines:
up to 1500 HP - naturally aspirated
up to 1200 HP - forced air induction
Specifications:
Brand: Aeromotive
Product Line: Aeromotive Aluminum Stealth Fuel Cells
Part Type: Fuel Cells
Part Number: A27-18660
Capacity: 15 gallons
Fuel Cell Color: Natural
Fuel Cell Material: Aluminum
Foam: No
Sending Unit Included: Yes
Sender Ohm Range: 0 ohms empty, 90 ohms full
Length (in): 18.000 in.
Width (in): 20.000 in.
Height (in): 10.000 in.
Outlet Fitting Quantity: One
Outlet Fitting Size: -10 AN
Return Fitting Size: -8 AN
Tip Over Valve Size: -8 AN
Sump: No
Quantity: Sold individually.
Notes: Includes an Aeromotive 11101 A1000 electric fuel pump and pre-filter built in. Also features two -8 AN rollover-proof vents.
Interior of the new Aeromotive Stealth fuel cell
Item #: A2718660
Our Price: $789.99
Quantity:
Description
A27-18660
Features:
15 Gallon Capacity
Carbureted Engines:
Specifications:
Brand: Aeromotive
Foam: No
Sump: No
