99' Z-28 hesitation?
Old 08-06-2009, 09:52 AM
IXWHITE TIGERXI's Avatar
Default 99' Z-28 hesitation?
I have been having hesitation problems with my car since I bought it 2 years ago. I was told I had an intake manifold gasket leak so I replaced that. Also new plugs and wires. Does any one have any suggestions? My power cuts in and out, very strange. Maybe injectors?
Old 08-06-2009, 10:18 AM
Old Geezer's Avatar
Some datalogs are a place to start...
A list of what you know to be done to the car is also pretty much necessary B4 suggestions are offered..
Old 08-06-2009, 10:22 AM
Im not quite sure what datalogs are sorry. The only mods are slp exhaust and k&n filter.
Old 08-06-2009, 10:26 AM
dragonrage's Avatar
Datalogging = hooking up a tool to the ECM and logging parameters while you drive the car, so you can see what was happening with the engine/sensors when your problem happens.
Do you have any other problems like surging at idle or sporatic idle RPM or anything else? When I had a vacuum leak in my Camaro it was at the PCV valve. The hose split open.
Old 08-06-2009, 03:14 PM
no, the idle is good, it just hesitates when i'm on the gas the power just cuts in and out.
Old 08-07-2009, 08:54 AM
I would like to try the datalogger but where would I find one?
