fuel pressure vs idle/cruise AFR?
Old 08-13-2009, 07:25 PM
ayousef's Avatar
Default fuel pressure vs idle/cruise AFR?
Well, im trying to figure this out, and while I could do the check myself something came across my mind and im out of town so a little help would be appreciated.
Question is, a rough figure on how much could 2-3PSI of increased fuel pressure incfluence idle and cruise AFR
427 TT, 80lbs high-imp injectors, 2.5bar SD tune.
Old 08-14-2009, 09:33 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
it will change it approx 2-2.5%.
Old 08-14-2009, 10:28 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
% Change in flow = Square Root of(P2/P1)
so, lets say you have 60PSI and it increases to 63
You would have sqrt(63/60)= 1.0246950765959598383221038680521
