need help with fuel set-up
Old 08-25-2009, 12:15 AM
needaz28's Avatar
Default need help with fuel set-up
ok so I have ran out of pump/injector. I have a set of 60# inlectors,a set of fast rails/fittings. I looking to get a return style set-up going. I'm looking to get a 1:1 regulator. have a 2nd 255 on the way as well.
can I just use these fittings
RUS-640853
RUS-640863
and just run it up from the tank, then use the evap line for the return line? I was reading something about it, and I think these fittings should work. I read the dual pump sticky but I dont recall it talking about return line and what fittings to buy.
thanks
Old 08-25-2009, 11:29 AM
Nasty N8's Avatar
DO NOT use the EVAP line it is your fuel tank vent and a very good setup please leave it intact. I have line kits to convert your system to return. Give me a call with some info on your setup and I can help you get exactly what you need.
