Heads & big cam is 26lb can make more hp??
Old 09-04-2009, 09:15 AM
vette-q8's Avatar
Thumbs up Heads & big cam is 26lb can make more hp??
hi
my car made 390rwhp with 26lb so the dyno tuner sad change it to 42lb and change the fuel pump i changed the fuel pump walbro 255 &filter i have the 42# now but still not changed so will the car will make more hp &tq after the tune ??????????
camaro-z28 -2000-m6 - 347 frg dimend piston (dish -8) 2.02-1.57.59cc ls6 cartek heads stage 2 spec3+ &flywheel,rearend 3.7 full bolt ls6 intake bbk80 UD Pulley cam 235-240lsa111 si6
Old 09-04-2009, 11:32 AM
Nasty N8's Avatar
Really depends how he tuned it the first time. If he ran out of injector and went safe yes you will pick some up as he can get the fuel ratios right.
