Are fox body mustang injectors a direct drop in for ls1 camaro?
yellow tops =24lbs at 58 psi
blue tops = 28lbs at 58 psi
brown tops = 42lbs at 58psi
Hi, I have a 98 Z28 with a LS6 block and a 382 stroker kit, Comp Extreme Energy Camshaft (Duration @ .050 Int 216 Ext 220) (Valve Lift Int .525 ext .532) I'll be running a meth kit, 2 pumps in the tank, running a #8 line into a bigger fule rail. I am going to run a upgraded turbo kit from STS. With that all said, what injectors should I run? The kit is comes with the 42lbs. injectors. But I don't think that will be good enoght. I have a 1989 TTA so I know somewhat about it. But that is the v6 turbo. I know what I would do with it. I know I will only be running about 8 pounds of boost until I change the pistons to lower the compression some. So what do you think?
Jon
