Siemens 60#
Siemens 60#
How are these injectors? How do they compare to other brands?
I have a chance to get ones with 4k on them for $250 or a set with only a dyno session on them for $310.
What do you guys think about them and which would be the better deal?
We put these in a buddies car this year. He got pretty much the same deal you are looking at. He claims they are the biggest nightmare to tune at partial throttle and idle. Mainly because no one has the correct values to tune it properly.
To get the correct values, you need to pay for the information. Granted a big name tuner will most likely have these. But, if your tuning your own car it's an issue. 42's are much easier, just because the injector isn't SO big.
Don't get me wrong, these are great injectors. But this is definitely something to consider before buying.
Even before Greg B took the time to lay the OE data out in our format, they were still very easily manageable if you understand what you are looking for.
I would say that it should not be a consideration at all when buying them. I cam make them run perfect on a bone stock car.
