Help with dual intank pumps and upgraded lines.
Old 11-06-2009, 05:09 PM
pdasterly's Avatar
Default Help with dual intank pumps and upgraded lines.
I have a 02 camaro. Ordered two walbro GSS340 pumps. Should i get 3 of these and just run new lines?
Old 11-06-2009, 10:24 PM
koolaid_kid's Avatar
Have you read the sticky at the top of this section? Most put the "y" in the tank and join them there, then use stock lines from there on.
Old 11-07-2009, 09:13 AM
396375's Avatar
I agree on the sticky.Well writen.Unless you are making crazy power then the stock lines will work fine.A lot of people use the stock feed line as a return line and run a new #8 feed line.
Good luck.
Attached Thumbnails Help with dual intank pumps and upgraded lines.-assorted-shots-c5.jpg
Old 11-07-2009, 12:14 PM
pdasterly's Avatar
looking for 1200 rwhp give or take. The pumps will be Y together inside the fuel pump assembly bucket. I want to run two hot wire kits and a hobbs boost switch. I read somewhere that i need a minimum of -10an. I want to run the two pumps together inside the factory fuel bucket. The lines running to the filter, I think i have two options, buy a -12 stainless line or run some aluminum hard line -10 i think with the correct adapters. Aftermarket fuel filter installed and -12 hose to a aftermarket fuel rail with fuel pressure regulator installed after the rails. I will be running 90lb injectors, high impendence
Old 11-07-2009, 09:01 PM
SStolen's Avatar
You're going to need three of those pumps to put down 1200rwhp. And with that much power, I don't think I would risk that set-up with a basic 'baller on a budget' fuel system. You need to get a real set-up. You have to pay to play and at 1200rwhp, you definitely want to play. If you don't, It'll turn into one of those save money now but pay more later things. Good luck with whatever you decide on.
Old 11-09-2009, 02:05 AM
pdasterly's Avatar
what would you recommend, i want to keep the stock tank
Old 11-09-2009, 01:24 PM
Nasty N8's Avatar
You are not going to make 1200rwhp with the stock tank and dual pumps. The dual setup when done correctly is good to about 1000rwhp. More than that you need a big external pump pulling fuel from a sumped tank. Give me a call we have a system to suit your needs. Including a new tank with builtin internal race pump and filters for very high HP street setups. Extremely new so give me a call for some details.
Old 11-19-2009, 06:00 PM
MIGHTYMOUSE's Avatar
def not gonna fit 1500hp thru that fitting.
id like to see 3 walbros inside the tank tho.
or runner up a walbro and a bosch might sneak in there
Old 12-23-2009, 02:52 PM
5 Liter Eater's Avatar
BAM!
http://forums.corvetteforum.com/c6-f...e-c6-fuel.html
Old 12-24-2009, 10:23 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
3 intank pumps inside the 99 up f-body bucket will not fit. I've built triple intank setups, but they require quite a bit of modification work properly.
If you are interested in a complete setup, I can provide everything you need.
I have a few options for intank kits, plus an internal/external combination if you want to go this route.
Old 12-24-2009, 10:31 AM
would love to have that gimongous hole in a n f body tank.. then it would be breezy.
Old 12-25-2009, 10:44 AM
elias_799's Avatar
where do you guys get the y fitting to join the two pumps together ?
Old 12-25-2009, 09:57 PM
TT-TECH Veteran
Inspector12's Avatar
Seen it done its a PITA as part of it had to be put together in the tank. I have also seen two Bosch 044 pumps with a bulkhead fitting at the back of the tank dual #8 feeds with #10 inlets that looked very promising but I never have tried either of the setups as I haven't had the need yet etc...
Quick Reply: Help with dual intank pumps and upgraded lines.
