Fuel system upgrades
I was wondering if I could maybe get some help with a parts list for fuel system upgrade. Dont want to go overboard if I dont have to due to budget, but want to be safe. My mods will be.. Functional ram air, Lid, long tubes, tsp true duals, 799 heads unported, LS6 cam. Gonna spray a 100-150 shot as well every now and then.
Upgraded single fuel pump and however you want to hotwire it. I hear good things about Casper's electronics' kits.
If a dry shot then you need bigger injectors, 32lbs should be enough. If a wet shot, the fuel solenoid and nozzle will handle your fuel so stock injectors are fine.
Stock rails, lines, and regulator are good for that power level.
