Broken injector part, is this an issue?
I ordered a vette fuel rail with injectors off of ebay. I had them shipped to a relatives house in the states, the rails and o-rings and all of that is in good condition. However my relative said that at the bottom there is this brown/orange plastic thing that sorta looks like a seat. On a few of the injectors this part is chipped or broken. Is this an issue? Is there a quick fix to this?
If you don't replace them you could get a vac leak from the injector not sealing when the o ring starts to corrode
Hey FIC, thanks for the quick response. Yes the injectors are the stock gray LS1 injectors. The part you are describing seems to be what I need. I tried searching all over your website but couldn't find the part listed anywhere. I checked the LS1 section as well as the rebuild kits sections as well, can you tell me what the part is called or direct me to where I can find them on your site?
http://fuelinjectorconnection.com/sh...&productId=230
