42# green tops
Old 02-08-2010, 07:54 PM
domestic<import's Avatar
Default 42# green tops
are the bosche green tops a plug n play injector, sorry for the short question searched and couldnt find anything
Old 02-08-2010, 08:00 PM
69LT1Bird's Avatar
Depends what you are plugging them into, they may plug in or may not. Might be the right height, might not. Tuning, no, you need the correct injector data for the tables.
You are better off call Jon at FIC, fuelinjectorconnection.com to get the best setup for your car.
Old 02-08-2010, 08:42 PM
ZL1Killa's Avatar
what connector type are they? EV1 EV6 uscar minitimer? shorties ?? there is more information.
start looking stuff up please. I just found out that the ls1 typical from 2001 is a EV1 bosch style minitimer. took me 15 minutes to find all that out via google
Old 02-08-2010, 08:46 PM
u may have an understanding of the ls1 and the lingo that goes with it but i dont so even if i found the info u did it wouldnt have meant anything so unless u want to be helpful please do not post in my thread telling me to search thnx.
however i have a 1999 ls1 z28
Old 02-08-2010, 11:18 PM
wytry's Avatar
Call Jon at FIC as mentioned. He steered me in the right direction, great guy.
Old 02-09-2010, 10:03 PM
ZL1Killa's Avatar
the ls1 has a bosch ev1 style "minitimer" connector, seeing you have a 99 ls1 I would say that the bosch green tops would fit your car fine, and be plug & play. I actually just found out the connector type the other day as I had to find out to properly order all the parts for the injectors I have just ordered.
if anything I would call Bosch or try and find the part number on the green tops you have and go from there. you will have to get the car tuned for the injectors however.
Didn't mean to be an ***, but the only way to learn is to search & call and find out. It may seem like things are hidden & information is hard to find, but its there.
Old 02-09-2010, 10:20 PM
thank u for the info, i appriciate it
