New regulator? NED ADVICE FAST
Old 02-11-2010, 10:41 AM
jeeperanthony's Avatar
Default New regulator? NED ADVICE FAST
My swap is running rich due to the fact that it is pushing 100(yes 100) PSI to the rails. I am running the regulator below, and am now told it is not in fact a regulator. What regulator should I run to keep the single line fuel rail?
I am running a walbro 255 and have 6 AN fittings on both ends if that helps.
Old 02-11-2010, 10:48 AM
Nasty N8's Avatar
I dont know who told you its not but it is a Corvette Filter/Regulator. Measuring 100psi at the rails? sure the gauge is correct? Maybe just a bad regulator.
Old 02-11-2010, 11:07 AM
If the guage is off, it isnt by much. I could just slap a new regulator on it, but how long will that last?
Old 02-11-2010, 11:10 AM
Nasty N8's Avatar
It should last for quite some time it is a factory reg. lives long time on factory Corvettes.
