Octane Boost questions
Most of us are pretty religious when it comes to putting the premium gasoline in the tank. But what is the backup plan in case you're out in the middle of nowhere and they dont have a premium pump? I carry a bottle of octane boost in the trunk but I'm rather skeptical about how much of it you'd need on a full tank to raise the octane from say 87 to 91. Is there a formula? I believe I've read that you need 10 points of octane boost to equal 1 true octane number.
I accidentally put 87 octane in once and realized it right after I did so I added a single bottle of that Octane 104 stuff. The engine detonated and ended up ruining the block on what I presume was the same tank of gas (can't be completely sure) sometime later. It's really hard to know if the detonation was caused by the gas or something completely different but I do want to be sure to get the octane levels correct, should there ever be a "next time" when a lower octane fuel goes in. Anyone have experience or knowledge in this department?
