ford racing 30lb injectors
Old 03-10-2010, 09:14 PM
slayer performance's Avatar
Default ford racing 30lb injectors
will this part number injector fit my car? M-9593-B302 i know with 60psi fuel pressure they will be around 36lb. i found some for $150 barely used, is this a good deal??
Old 03-11-2010, 10:07 PM
FICINJECTORS's Avatar
they are a drop in and will flow 36 at 58psi
Old 03-12-2010, 06:36 AM
ok thanks!!
Old 03-12-2010, 07:40 AM
Jazz-LT1's Avatar
I am using these currently. They seemed to be a bit loose when I installed them but once the rails were tightened there were no issues. Car runs great and was tuned by PCM4Less for the new injectors.
Quick Reply: ford racing 30lb injectors
