what size injectors
what size injectors
im putting a t4 60 turbo on my stock ls6 camaro...what size injectors do i need and where is best to buy them... i was told that the 42 lbs from ford racing would work but id rather stay away from ford parts...
42lbs will get you there
as far as ford parts that is one of the funniest things ive heard but ill be nice
injectors are like pants they are all made in mexico(maybe) and everyone puts there own name on them
the new mustangs use the same type injector that is why you were told that
what are the specs on that t4 60? I'm not the smartest turbo guy, but do you have any idea the compressor size & etc?
if you are putting on a 60mm turbo....I highly suggest you upgrade to a 67mm. the LS series motors are freaking air pumps. You won't make more than ~450rwhp with a 60mm turbo.
a 67mm will put you in the 520 range
you will need fuel pump, injectors, all of your normal turbo parts, hot side, cold side, wastegate, blow off valve.
