Fuel system questions
Old 04-10-2010, 05:47 AM
Restricted User
transammiller's Avatar
Default Fuel system questions
alright finishing up my turbo build and i have lots of questions regarding my fuel system. i have my FPR return going back through the EVAP line. how do i splice the evap line into the return line at the bucket? also how do i remove the stock fuel pressure regulator? i looked under my car and all i have is a pressure line with a filter to a "T" block then that line returning to the tank and an EVAP line coming from the motor. also when i prime the pump now with the fuel system setup how it is i cannot get any more than 20 psi but it cranks right up and idles great. whats with that? i trigger the 2nd pump and it will not go over 20 psi. i have adjusted the spring and still nothing.
Old 04-10-2010, 06:37 AM
jomomma's Avatar
The regulator is at the top of the fuel bucket in the fuel bucket. There is a clip you take off of it to expose the diaphram in it.
Old 04-10-2010, 08:23 AM
Restricted User
is it the light brown little cylinder?
