What do you think.
What do you think.
I'm using a ls1 from a 2002 vette. It has two tanks so I assume that it has two pumps.
How much power can I make at the tires with the stock fuel pumps and injectors?
I'm trying to see what will be cheaper. ls6 heads,ls6 intake,cam, tune or forced induction,fuel mods,bov,wastegate... Thinking small ebay t3/t4 knockoffs or gt45 knockoffs
What do you think.
What do you think.
LS1TECH Sponsor
A Vette has 2 tanks but only 1 fuel pump.
The Z06 has a better pump than the others.
I would expect under 500rwhp on the standard pump.
Maybe closer to 575 on the Z06 pump.
There is an aftermarket larger version for 600+ or I make a dual pump that will get you to 1000rwhp.
Injectors will be maxed before the pumps.
